Upper door seals?
MikeB
North Texas
I recently installed new door seals on my 82 C10 Custom Deluxe, the ones that mount to the cab.
Several vendors also show "upper door seals" for 73-87 pickups that are mounted on the door, but I see no sign of those having been used on my truck. Were they used only for certain years, or upscale models?
Here's the SoffSeal upper door seals:
https://www.soffseal.com/ss-9352
What's the story on that?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I always thought they were only 79 & 80 trucks, but Precision shows for 78-82. The OEM ones had screw attachments at either end (molded in metal tabs). I had installed them on my '77 K5 back in the early 90's.
Precision sells them for about $31 ea. You have to use adhesive between the screws, but I'm sure you could use 3M tape to do the same as above.
https://www.prp.com/product/detail/...nt=24&year=1979&make=GMC&model=C1500&type=All
Those weatherstrips were installed on the uplevel trucks. It went into the later years too, but maybe with a slightly different design.
legopnuematic
Licensed Junk Dealer
MO
Spencer
If I am not mistaken was standard on the Cheyenne and above trucks (or GMC/Year difference equivalents) My 76 has em (Cheyenne), 79 doesn't (Custom Deluxe)
rlfdavin
