Unused ground buss and...
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
A few quick questions:
1. What accessories are typically tied into the ground buss located behind dash on driver side?
2. It’s been a while since I’ve driven my truck. I don’t recall if not having my seatbelt on or not having this black/white wire hooked up produced a buzzing or warning light?
3. If so, it’s looking for a path to ground, correct? I could coil it up and plug it onto the ground mentioned above.
chengny
Without knowing the model year, it's difficult to say for sure what that wire is. But if it is the ground wire for the seat belt warning light/buzzer and you connect it to the ground bus block, the warning light and buzzer will stay on until the timer shuts them off.
The BLK/WHT 238 is connected to a NC switch in the seat belt retractor. The other side of the switch is connected to ground.
When the belt is extended, the contacts open, the path to ground is broken and the warnings are disabled.
Look at your fuse block. Are there two flashers - plugged into the upper left and lower right corners - and a black box mounted to the top? Like this:
Or is there only one flasher plugged into the fuse block (lower RH corner) and a detached "convenience center" with the other flasher? The CC would be mounted to the firewall to the right of the steering column:
The convenience center and single flasher fuse block came into use starting in 1985. That should help you dial in the MY of your truck. That's very useful information that you can provide when asking for help with electrical systems.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
So if I’m reading your post correctly, I can wrap it up out of the way and not connect it and it will never buzz?
chengny
Yes, I believe that's correct.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You know for sure you ****** up when it burns to the ground..
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Rock solid post there chengny. :cool:
chengny
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
True.
Not 100% sure I’m running a full carpet kit yet. Probably will. I doubt the paint on sound deadener will be enough.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
True.
The $ you save on carpet can go towards good quality auto sound mat... the the rubber floor liner over top.
If you run loud pipes it will quite the road noise!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The road noise is a concern. It’s a close second behind metal preservation and rust.
It would be sweet if someone made a marine grade carpet kit for squares. I’ll have to look...
Then I could just have nice all weather mats over that.
jlyon1006
