Under Dash Wiring Mystery
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
PROGRESS - Thanks to you guys I was able to get cargo and dome lights. I plugged the orange wire into the top left row circuit on the fuse box. The ribbon wires from green box marked "AC"remains plugged into the instrument panel just to the side of the speedometer cable. I see a recommendation to plug the actual green box into the speed sensor. I need to find the speed sensor, but first need to know what it looks like? Still no running and dash lights, the light switch is new, not sure what else could be the problem. As suggested by several of you, the grey and tan wires were speaker wires, so they are not an issue.
The big remaining problem is the 5 AMP fuse/circuit the powers the dash and running lights. If anyone has any ideas on steps to take for trouble shooting this circuit it would be much appreciated. Thanks again.
The ribbon cable on the green book leads up to the optical speed sensor inside the speedo head. There is a wheel with slots cut into it, the optical speed sensor counts how many times it “sees” the windows in a certain amount of time. It then uses that to calculate speed.
The 3 wire connector with yellow, pink and black plug into the other end of the A/C Delco green box.
mgoldbach
athena al
Mark
Okay, I replaced the 5 AMP fuse with a new one and checked the fuse box contacts (for the 5 AMP fuse) and they are both tight. Still no power at the orange wire connection at the light switch, thus no running lights. I started to check the orange wires from the light switch and I need to disassemble more of the dash to proceed. Please bear with me, I really appreciate your help with this. Thanks again.
mgoldbach
athena al
Mark
Matt69olds, Unless the connection part of the Green "AC" box is missing, right now it is not possible to connect the yellow, pink and black plug into the green box. Please see the enclosed photo. Thanks for your suggestion.
mgoldbach
athena al
Mark
Matt69olds My apologies, I physically tried to connect the yellow, pink and black plug into the Green AC box and it worked. Just from examining the plug I thought this will not work....little did I know. So with this plugged in, what does this do? Thanks again, you have been very helpful!
Jgonick
West Texas
Joel
Wrong fuse- you need to check the 20 AMP fuse for TL/CTSY
see attchment
lefjlandon
