Turbo 350 issues
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Do you have a welder? Next time you need to drain it just drill a hole in it and weld a washer nut to it later and make your own plug.
77 k 20
ken
K20 Bonanza
Yes I have a welder. That's way to easy. Thank you again
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
77 k 20
ken
K20 Bonanza
Both great ideas Thank you for the ideas.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Well here's what I found. As far as I can tell the vent orfice is open. Was able to take some wire and stick it in about an inch or so. Never really found a hole that the wire would go into the transmission. The pan is a stock metal pan not any deeper than my old 350 turbo in my 72 K10 It does have a standard size cooler in front of the radiator in line with the one in the radiator. As far as the convertor it appears to me as a stock replacement size and type. Rethinking when I filled it up I'm sure I was wrong about the 9 qts but 7 qts for sure. My dipstick still reads 1 pint low now and driving into town and back. Thanks again for your advice. Nick do you have a stock turbo 350 pan with a drain plug in it and if so would you be willing to part with it. I can't find one up here.
I've got this one on my old th350 I sold a while ago.
Compatible/Replacement for Chevy/GM Turbo TH-350 Steel Transmission Pan (Deep Sump) - Chrome https://a.co/d/hzUmCh6
Was really good fit and worked out well
77 k 20
ken
K20 Bonanza
Thank you I'll take a look
thatgermanguy
