Truck won't turnover sometimes
Fjordlander
USA
Kyle
Scottsdale K10
V8
I have a 1976 Scottsdale 4x4 that usually runs great but sometimes I go to start it and it turns over once and then nothing happens. I've been able to get it going by disconnecting the ground and sparking it on the positive to short the starter (advice from someone I know) but that doesn't always work so I'm not sure if it's the starter or something else. The battery is almost new and even when the truck won't start the lights will still come on and are plenty bright so I don't believe it's a battery issue. Any suggestions would be greatly appreciated as I'm new to all of this!
dvdswan
Port Orchard, WA
Dave
What are the conditions of the battery cables? New, recent, or couple of years old? You could have cables that are corroded inside the cable.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Check ground cable connection to frame or block?
Fjordlander
USA
Kyle
Scottsdale K10
V8
Cables are maybe a year old. I might replace them anyway just to eliminate the possibility
Fjordlander
USA
Kyle
Scottsdale K10
V8
One of my grounds is a smallish gauge wire so I might replace that with something bigger. Otherwise, the ground connections are good and clean
dvdswan
Port Orchard, WA
Dave
Generally, cables don't corrode within a year. As @82sbshortbed stated about checking grounds on the frame or engine. Any paint, primer, rust, etc. will degrade the path for voltage to flow. Clean metal, washers, bolts, and terminals are key.
Gray Beard
Sykesville Maryland
Toni
R20
You may have a bad spot on the starter solenoid. The copper contact gets a bad spot it will act up. You can pull the solenoid and take it apart and flip the copper contact point in the end cap. Quick fix.
I do not understand OPs statement. Taking off the negative battery cable and sparking it to the positive. Negative cable disconnected from battery,now you have an open circuit,your negative cable can't spark to the positive terminal. Exactly what are you doing? If you are taking the negative cable off then putting it back on and then the truck starts I would think you need to clean your negative post and the end that goes on it. If it's a repair end take it apart and clean it. AAAAH. Dammit I've gotta start looking at thread dates before I post.
thatgermanguy
