iforsman
- Dec 9, 2022
- Mt. Juliet, TN
- Ian
- K10
I'm looking for some pointers. i recently rebuilt the engine and broke it in. Engine runs and idles great, however when I put it in gear it dies. I've tried several different things but no changes. Timing is currently at 8 BTDC (have tried from 4-12 but 8 seems to be the best), checked for vacuum leaks and found one hose that was cracked (transmission vacuum line)replaced it and no change. current intake vacuum at idle is 14/15 which seems a little low to me. Any suggestions on what else to check as i'm at a lost.
specs: SBC 400, stock heads, running a Comp cam 4X4 extreme 218/226 cam, Edelbrock 1406 carb
