austinado16
- May 25, 2012
- Central Coast, CA
- Todd
- 1990 w/307k miles on the clock
- GMC V1500 Suburban SLE
- 5.7L TBI/4L60/3.42's
IMO, you never want to do flushes on engine or automatic transmission. All the flush does is dislodge and stir up all the shavings, grit, crud, and other foreign matter that is a fairly normal byproduct of engines and transmissions. This stuff is normally packed into corners and other areas, where it does no harm. A flush breaks it all loose and sends it free to roam around. Typically there is a failure of some sort later on, and the shop doing the flush will say, "Well, that's not due to the flush...look at how many miles are on it."
Note that the place doing the flush did not remove the trans pan, clean it, and replace the trans filter. Why? Because this is schlock work that they bang the customer hard for. They've paid umpteen grand for that flush machine on the promise that it's a money maker......Bang the customer for $150 and all your "tech" has to do is plug the machine in to the transmission, turn this button on, and come back when it's done. Meanwhile the tech is double dipping, working on another vehicle. Huge money maker. I love the NBC Los Angeles investigation into Jiffy Lube's BS, where they were selling flushes and not doing them, and there was no way for the customer to know.......until NBC planted some lipstick cams in some cars and caught them.
I'd suggest dropping and cleaning the pan, and replacing the filter. Refill with Dexron VI, which is synthetic and backwards compatible. Then have a professional adjust the TV cable. This requires a pressure gauge be hooked up to the transmission. Read more about the process at www.bowtieoverdrives.com The TV cable needs to be perfectly adjusted so that the instant it moves even a few thousands, the trans pressure also immediately rises.
I've made the gauge and do my own adjustment. It's easily done once you see how the transmission pressure responds.
If you wind up needing a transmission, consider it a blessing. There are a ton of upgraded parts available for them, so you either build, have built, or purchase, (bowtie overdrives) a transmission that's 10 times better than the original.
