79dentside
- Nov 20, 2019
- Kansas
- Brandon
- GMC Sierra Classic
Hello, got a question. I am experiencing a humm/howl at 45 that fades in and fades out about 50 mph. I originally thought it was rear end, but it seems to not be. I got the truck off the ground and ran it through the gears and I went around with a stethoscope and it was QUIET. Quiet at the pinion, quiet at the carrier bearings, quiet at the back left wheel bearing... I put new wheel bearings in because the back right went bad. I thought surely this was my noise, nope. Still howls between 45-50ish
I am wondering if it is transmission noise because the rear end was rebuilt at some point (not saying it can’t be the culprit) If I accelerate it howl at45, if I decel it howls, but there is a break in sound when I take my foot off the accelerator for a second.
The noise also is not existent at 45-50 if I am in second gear (manually shifting it).
To me it sounds like a resonance thing, but I’m not sure. In second gear it doesn’t make the noise, in 3rd it would
Also, the tailshaft spline deal-io; that the driveshaft splines onto, has some metal mixed in with the trans fluid which made me wonder. The trans fluid on the dipstick is stupid clean, it’s looks like it’s brand new.
I don’t know, I just was looking for a sounding board. I don’t want to grenade something because I neglected a noise. Thanks!!
