transmission is supposed to be th400 says 400 on plate on passenger side of trans numbers on bottom of id tag are 17-cl 43491 as best i can make out had a drum brake on trans tail shaft and has th400 oil pan is this a th400 or something else
If the two big letters on the ID tag are CL that's a TH400 out of a GMC school bus from 1973 or a TH475 from 74-80; The TH475 is identical in appaearance to a TH400 however has straight cut gear sets and, I believe, a heavy duty direct clutch pack (6 frictions) in the drum. Highly sought after for hp/hd builds.
There should be a number showing in the middle of the ID tag which represents the model year. I imagine yours will show a number somewhere between "73" and "80"
Post a picture of the ID tag.
Here's mine on the tear down bench
