Transmission grinds going into L or R
84K30
SWPA
1984 Chevy K30. 454. NP435. NP205. 33k on the clock. It has definitely turned over at least once. I have put about 8k on the truck since I purchased it in 2019.
Recently, my transmission has been grinding when I shift to Low/1st or Reverse. I adjusted the clutch (mechanical linkage) and the issue was resolved...until I drove it a few miles and the symptoms resumed. This seems to be a recurring phenomenon. The transmission goes into all of the other synchronized gears without issue. I do not hear any strange noises. The clutch pedal sometimes shudders while driving. Sometimes the transmission will go into Low/1st without grinding if I shift into 2nd gear beforehand. Other times, I've had to kill the engine and drift the truck a few inches in neutral for the teeth to mesh up before restarting.
Any ideas what might be going on? Is my clutch shot? Thanks.
-Eric
85K304SPD
Las Cruces, NM
Richard
So your truck has the 4 speed overdrive transmission ,NP A 833, or the 4 speed with the granny gear low? SM 465
84K30
SWPA
Transmission is a SM465. Sorry for the confusion.
nvrenuf
Mobile, Al.
sm465 L and R are unsync'd and do that all the time
This ^^ Normal operation.
If it’s always done it but now it’s worse, the clutch likely needs to be adjusted.
85K304SPD
Las Cruces, NM
Richard
If you are not moving, with the clutch in, they should not grind. If you are trying to get it into L or R with it rolling, they will probably grind a little. If they grind when you are not moving, your clutch will probably need adjusting or replaced.
Could be time for a clutch or could be worn synchros. A couple of my previous mustangs would do that, had to go to 2nd or 4th before reverse cuz of worn synchros
84K30
SWPA
This is occurring while stationary and has not always been the case. I’ll try adjusting again and start looking into a new clutch. Thanks!
Carb'ed Vortec 350
If adjusting the clutch doesn't help, replace the clutch. Unsynchronized gears always grind a little bit. But if they grind and you can't get them into gear, the clutch isn't disengaging enough for the input shaft to slow down. If you replace the clutch, get the complete clutch kit that comes with the disc, pressure plate, and throwout bearing. And don't forget to get your flywheel resurfaced while you're at it.
SquareRoot
Remove and replace with NV4500. Report back.:popcorn:
84K30
SWPA
Update: It was a clutch adjustment issue. Sought the assistance of a buddy who is more knowledgeable and competent than I and we got it resolved. Thanks for your assistance.
84K30
SWPA
Encountered the same phenomenon again today, after putting another 2k on the truck. Groaning going into 2nd and sometimes just wouldn’t. Adjusted the clutch and took it out for fuel. Drove like it normally does (no abnormal sounds, went into and out of gears effortlessly). I shut it off at the pump.
After getting fuel, the clutch pedal was almost too hard to depress. With some effort, I got it shifted into neutral, started the engine, shifted into gear and heard a horrible grinding/metallic sound (not typical gear grinding).
I shut it down and coasted it into a nearby parking spot. I’m now looking at having the clutch replaced by a shop.
Does South Bend still make a quality clutch? Are there any clutch other manufacturers that I should consider?
Thanks,
JoeyPepperoni
