agustaf
- Jul 24, 2024
- Kalispell, MT
- Andrew
- K10
While driving the other day, truck started losing power to the drive train like the transmission was slipping. Then suddenly died. Pulled to the side of the road. Was able to restart but when shifting into drive felt no response from transmission and engine would just rev with the gear shift in drive. Under the truck is a puddle of what turned out to be engine coolant. There is engine coolant on top of the engine block and after removing goose neck and temp regulator coolant overflowed out of the engine block. Is this a result of a failed water pump?
