Transfer case adapter
tteiber
St. Brieux, Saskatchewan
Tanner
K1500
Hello so previous owner installed an adapter kit to put a 2wd transmission in my truck. Now I wanna reinstall a 4x4 transmission with a short shaft. Where would I be able to buy a new front plate for the transfer case the brings the splines back to normal. Np 208 tcase. Blue is one I planned on putting in other is old transmission with spacer.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I think ORD might have what you need.
MadOgre
NA
NA
NA
NA
NA
Hit the junk yards!
Won't work. The trans you want to install has the '80 and earlier output shaft, it simply can't be used with an np208 which wasn't used until '81 (and a longer output shaft).
MadOgre
NA
NA
NA
NA
NA
It should look similar to that with the adapter on. Good catch bucket
ExtraZ
