Torx sizes
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
I'm very new to GM products and don't have any torx drivers
What sizes should I be looking to purchase...
Thanks,
GM Newbie...
IIRC, T10 and T15 will be the ones you'd use the most. Now if you get into body hinge bolts and such, those get up there in the T50+ sizes and I'm not 100% certain on those. But, pretty sure if you have a T10 and T15 that should cover most of what you'll need.
Someone please correct me if I'm wrong. It's been awhile since I needed one. Talilights and Headlight bezels is the only thing I recall using them for.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
T50 and T55 are widely used for seat belts on newer stuff that's about all I use thought other then T15-T27 at work all the time. Then there is Ferd bed bolts that are a lil different T50 cause they have a rounded corner instead of a point.
v2500burb
Jay
v2500
350ci
10-4
Thanks
So that will cover tbi rebuild?
t15, t20, t25, t30, and t50 are commonly used on GM products, but it's always good to have other sizes also.
v2500burb
Jay
v2500
350ci
10-4
I'm getting torx bits as apposed to full size drivers
transportjockey
Albuquerque, NM
Nathan
454 V8
Ewww I was hoping getting away from jeeps would mean getting away from Torx head bolts... good thing I still have my set from the jeep lol
Sent from my SPH-L720T using Tapatalk
dljohnson55
