Top Radiator Clamps
I need a set of top radiator clamps for a BB. for my 85. If anyone has a set let me know.
85K304SPD
Las Cruces, NM
Richard
On my '85 big block, with the tall wide radiator, it is one solid piece that holds down the radiator. What radiator do you have?
I don't have one to be able to compare. Thanks for posting the pic. I guess I need the one piece kind. I'm putting a after market aluminum 4 row radiator in my Blazer.
Anybody have a one piece 454 radiator top bracket?
nvrenuf
Mobile, Al.
Since @85K304SPD mentioned it, the true wide diesel radiator uses the individual brackets with a plastic cover spanning the gap between them. The 1 pc top plate does not fit the extra wide diesel radiator, the unused wider bolt pattern holes can be seen in the pic in post #2.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
What radiator are you planning? I did the Griffin kit with fans & it fits the standard radiator support.
I have the Be Cool kit
CalSgt
CA
Casey
Dang…. Looks like the be cool’s are 21” tall and the Griffin is only 19.
Looks like LMC has BB rad top panels in stock for 81-87 square. Not sure if it’s what you’re looking for.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
81-87 bb plate from lmc on a small block truck, factory holes. For a four core. The lmc piece is definitely on the flimsier side, but it's held solid.
I might run out to the salvage yard by me, and see if any of the Squarebodies out there have one. Thanks for the help y'all.
85K304SPD
Las Cruces, NM
Richard
There is a few different sizes of radiators for these squares. Height and width differences. Brackets, shrouds, hoses, hold downs... dont forget the little rubber saddle things that they sit in... There is more variables than I ever thought there could be.
Bennyt
Surprise
Ben
I have one of these I can sell cheap if anyone needs it. I powdercoated it so it looks like new. I ended up going with a taller radiator to help with the AZ summer.
F1r3truck
