Top door hinge to door bolt one smaller than the rest
Big _Betsy_Red
Western Massachusetts
Wil
Blazer
350ci
On both sides there is a short bolt out of the whole door hinge bolt kit. I know it is top hinge top row I just cant remember if I took it out of the hole towards the inside or towards the outside. I am sure it is short to clearing something inside the window crank area and if I get it wrong I would have to take the door back off. Any ideas?
Also found this "Y" shape thinggy holding up my dash near the passenger door. Any idea what it is for?
legopnuematic
Licensed Junk Dealer
MO
Spencer
The second picture is a body shim, used for alignment of body panels, goes under the panel around the bolt.
Scott91370
Burleson, Tx
Scott
Sierra1500
Thread pitch doesn't look the same as the other bolts. You sure it's from the hinge area?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
All the bolts were the same on two trucks of mine, I just messed with the doors on both.
Keith Seymore
Motor City
Keith Seymore
4.3L
Looks to me like the bolt that holds the window track, or maybe the bottom of the vent window.
All the other ones are part number 3846202, and provided by either Lang or Ferndale Fasteners (same as the fender nose bolts).
K
gtewolf79
