To PCV or not to PCV
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
I don't think ill run it.
Iowan
Iowa
Calvin
K1500
350 crate
or maybe I will, I don't know.
73c20jim
Tombstone, AZ
So just having a PCV hose to carb base and a vent to the air on the other valve cover is only half a system?
If I plug the PCV will the carb need to bee re-tuned? Less air going into carb?
73c20jim
Tombstone, AZ
Reading up in the service manual, one side is intake and the pcv side is exhaust. Gonna keep PCV and get a new filter for the intake side.
436'd skylark
VT
Joe
2500HD
Durajunk
If I understand the PCV system correctly, it uses engine vacuum to pull crank case air pressure from the crank case. This pressure is counter productive to piston movement. That’s why race engines have vacuum pumps to create negative pressure in the block. In typing this I’m sure the PCV system has more to do with emissions crap then anything but negative pressure in the crank case is good positive not so much. Also if your system isn’t working properly oil can shoot out of the dipstick. Lol @RustyPile or @74 Shortbed could probably explain it better.
The vacuum pump you're thinking of isn't for ventilation. It's a crucial part of a dry sump oil system to control oil. It is not part of the pcv system.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The vacuum pumps are to help the rings seal. Dry sumps have suction pumps but they're to scavenge oil, not to pull crankcase vacuum.
Iowan
Iowa
Calvin
K1500
350 crate
Catch cans are what I would like to do.
jlyon1006
