Tire/wheel issues with local shop
Oldrider
NC
k2500
Just a minor rant on local shops.
I needed to have my 305/65 (33's) tires balanced. I have only lived in this town 2 years so was not too sure where to go. I went to a place that is not a national chain but has a big shop so I hoped they would know what to do.
After taking over 2 hours I got my truck back. The guy had installed wheel weights on both sides of all four rims. The original weights were inside only. I drove the truck home and it bumped worse than it had before the work.
A phone call back to the shop left me with nothing but a bad taste in my mouth.
A week later (I don't drive the truck much) I started having tires go flat. (wtf?) I first thought I had picked up nails. Then when refilling one tire I heard air escaping while I was pressing the air chuck against the valve stem.
I took a tire off and carried it to another shop. They said it had the wrong valve stem. They balanced the tire (inside only) also. I took them a second tire and they repaired it also.
Now I am riding much smoother and those two tires are holding air. I still need to take the rear two in for a valve stem replacement. At least I have found a shop that I can do business with.
Dougnsalem
That doesnt make any sense at all. Why would the first shop mess with the valve stems on just a balance? Those are pretty foolproof too, unless you have metal stems, or TPMS. What kind of wheel are you running? Got pics?
Did they use the wrong weights, and break the seal on the beads???
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Equal don’t do weights
Dougnsalem
Does that stuff actually work? I need to do some more reading on it. What happens when you get a flat? Can you still do a plug/patch on the inside, or does it get all slimed out like the crap tire sealant stuff?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
***** awsome. You won’t have to balance again for the life of the tire. It’s just sand if you get a flat just plug it air up and go.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The valve stems are fishy. Did they ask you to do them? If not, they probably wanted to get away with a $12-20 upcharge. That shop is a joke. Leave them a bad review on whatever outlet you desire.
Derrick
near Milwaukee, Wisconsin
Derrick
At least you found a quality shop to work with now in my town there is one good shop he is under the table he did good work for my grandpa then my dad and now me the only problem is he works slow but i have no problem waiting 40 more min for my tires to mounted and balanced as long as i know they are done right the first time. the only other halfway decent shop around me charges almost more than the dealer so I have to either work on my own junk or wait longer and let the under table shop work on it.
350 w/203
WHO were the Bozo's?
WHO were the Good Guys?
highdesertrange
kalifornia
mike
k30
just as a side note, you get a better balance with weights on both the inside and outside. highdesertranger
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Some wheels, like mine cannot be weighted on the outside. The trick is to apply the weights close to the centerline of the wheel. Most of the time, it's the tire that has heavy spots that throws it out of balance, unless the wheel has been curb checked.
True, but weights on the outside look bad and cause corrosion on aluminum wheels.
ExtraZ
