Time for a new clutch
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
Well its time to put in a new clutch. I've never replaced or even worked on a clutch before so any tips would be much appreciated. I'm looking for a stock replacement clutch such as this http://www.summitracing.com/parts/zzz-mu5505-1 . would this be the correct clutch for my setup? also i'm debating whether to resurface the flywheel or just buy new. opinions? thanks
Yeah, that would be a great clutch to use. I prefer having the original flywheel resurfaced. The aftermarket replacements are usually fine, but sometimes you run into issues with improper balance or poor quality material.
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
Zoom is a really good manufacturer for the price. I have a zoom ceramic disc in my k25. I'd reccomend the ceramic if you do a lot of hauling or pulling with your rig. It just takes a little gettin used to driving the ceramic
I prefer the OE flywheel too, but I'd let the condition decide. If it's heat checked real bad, or going to have to alot taken off to smooth it out, then replace it. Otherwise, have it machined and keep is best if you can.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
go to rock auto and order a ac delco clutch they are good quality and it doesn't cost a fortune. i got one in my truck and it is fine had it in 5 months and no problems.
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
New clutch is in, and she's driving as good as ever. Ended up getting the flywheel resurfaced for 25 bucks at south bend clutch. Napa wanted 55 to do the same work! I came across that thread before i put the clutch in. boy what a help that was! thanks irishman
ben_swager
