- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
How about a write up on a backyard toe in adjustment for us poor folk, that exist? My wheel is straight but it's pulling hard right and I am sure it is not a caliper or brake hose issue. I think the l/f wheel is toe'd in due to a slightly bent lower A-arm.
Uhh NO NO NO Dawg !!! You're Toe In issue is probably NOT the issue of the hard pull. Replace that bent A arm. The Toe In will help a little, and also help with the tire wear since it's scrubbing the pavement. That A arm is most likely throwing your caster way off and making that wheel drag. Kinda like a Zombie walk. Take a step with one leg, and drag the other, take a step and drag the other. Believe it or not, this can also affect your mpg on the highway. I wish to hell I still those half ton bodies, I'd send an A arm. I've scraped 4 half tons in the last 2 years all with upper and lower control arms.
