Thoughts on how to recover from a slightly cross threaded spark plug threads in head?
beady
Tidewater/Northern Neck VA
Mine
R20
Was installing a DUI distributor, coil, wires, and plugs. Got distributor and coil installed and old plugs out. Started installing new plugs and hit a snag.
454, #8 rearmost passenger side. Felt like it went in ok a few turns and then I started tightening with a ratchet, but it didn’t feel right so I stopped.
First thread of the new plug is a little rolled. Neither new plug nor old plug that came out will go in now past a turn or two, obviously I haven’t tried forcing it.
Pic of the new plug I tried to install attached, you can see the first thread is dicked up. There’s a little anti seize on it is why it looks odd.
Thoughts/options?
Thanks
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
My first thought would be a tool like this from a local parts store.
Get the thread cleaned up and rock and roll !
beady
Mine
R20
Is that deep enough/has enough clearance to get a socket on that hex and fit into the opening in the head?
I thought I read ppl saying those were too large in some cases.
I did pick up a 14x1.25 tap this evening, might order a single ended thread chaser before I try the tap though.
Truck82
Alderton
Christopher
^^Same^^
I have also installed a TimeSert in my dads truck
beady
Mine
R20
I just ordered a regular, tight clearance thread chaser and also a “back tap” which you insert to the good threads, expand, and back out. At least one person had luck on an iron head.
Back tap
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I bought something similar ( if not that one ) for Goldie but never used it. I THINK it will fit just like a plug socket but can't say for sure. Seems like it would be totally worthless if it did not.
Use a chaser. A tap is not first resort. A tap is designed to cut new threads,and will,not necessarily at the right angle and not necessarily at the right depth. Meaning you might run the tap mid thread through the remaining threads,which will substantially weaken the threads. Grease the chaser to collect the debris.
ChuckN
Bellinham, WA
Chad
It’s just how my brain works, but my first thought was “of course it had to be #8! It just couldn’t be #1 or 2”.
But, it is what it is. Looking forward to seeing how this comes out- keep us in the loop.
Robert Bare
MT
Robert
k20
You should be able to do it with a rethreader. However, there were made for years, rethreaders that expanded. You push them in, expand it, then back it out. You see, it starts down in the good threads and backs out, cleaning/cutting the threads. I would bet now only old time mechanics and machine shops have them.
  • Like
Reactions: WFO
tsgs84
md
Timothy
I agree try a thread chaser not a thread tap
gordies78
