TH400 trans service
jwright
st helena sc
jim
k20
Transmission pan is leaking fluid. Want to clean up the mess, reseal, and replace filter. Options on best gasket to use on stock pan.
JD Miller
Augusta, Georgia
JD
472 Cadillac
Straighten the pan. The sheet metal bolt hole area will probably need hammered back flat again.
Those expensive plastic ribbed reusable gaskets work great if you have a new or good flat pan.
Dont use any rtv /silicone sealer
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I don’t have a part number, but the shiny tan gaskets that comes with the TransStar overhaul kits work well. If the pan is flat and installed dry, it takes a rubber mallet the break the seal.
jlyon1006
