85k10383
- Jul 31, 2010
- Glengary, WV
- Ross
- K10 Scottsdale
OK all you Tranny gurus. My TH400 needs something, and I would like your help to decide what. The PO never rigged up the electric kickdown to gas pedal mechanism, so the trans will not downshift, pretty much ever. Secondly it shifts very softly like it came out of great grannies Coupe Deville. Thirdly, it seems allergic to high revs in any situation, I have not seen better that 3500 on the tach with the new engine. I have swapped out the fluid for B&M Hotshift, which i know won't do much, and replaced the pan with a B&M + 2. My questions are: What can/should I do first? Is it worth the dough to get a better torque converter (higher stall etc.) without also doing more to the trans? Will just rigging up the kickdown help a little? Why won't the trans hold gears under load? Like when getting on the highway, it upshifts at about 3200 1-2-3, seems like I wouldn't burn as much fuel if the damned trans would just let me keep 2nd gear up to about 4500 RPM. All opinions and advice very much appreciated!
Truck is running a Blueprint 383, TH400, 3.08 gears 33-12.50-15 tires if that helps at all
