Th350 with Gear Vendor or 700r4
Mike7ftr
Fresno
R30
I've been reading both ways on this. It's going on my 1ton 4x4 dually. I'll be running 37's. As far as I can tell they're both gunna be pricey. Should I keep my th350 which is cheaper to build and get the $plitter? Or, get the weaker, 700r4 and build the hell out of it? Both ways it looks like I'm in to it $2500.
Uhh, where's the option for the TH400/GV?
Lol, yeah I know... $
Personally, I'd go with the GV on the TH350. And a big trans cooler.
Mike7ftr
Fresno
R30
My bad. Just crawled under and looked at the oil pan. It's a th400. The back of the pan kinda looks like the lower portion of the state of Texas.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Have you considered a 4L80?
Most definitely a GV then! That's what I want to run in my K30 if I ever have the money. Until then, no OD is fine.
yevgenievich
Place
Name
Year
Model
Size
Th400+Gear vendor or 4l80e.
Mike7ftr
Fresno
R30
Th400 and gv. That settles it then.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You can’t go wrong with a 400 and a gear vendor. The only other option would be a 4L80. The computer will be kinda pricey, but unless you really need a aftermarket converter I think you could come under your 2500 budget easily. Try and find a good used unit, install a TransGo shift kit, and enjoy the durability of a 400, overdrive, and a locking torque converter
Jason Deckard
THE KVAN 4x4 MAN
Ellettsville Indiana
Jason
Chevrolet Pathfinder KVAN 4x4 highly modified. Built...not bought
Ramjet 350, NV4500 manual, 3.73, Atlas II
Yea 400 with a gv would be the bomb diggity
Mike7ftr
Fresno
R30
A buddy of mine said that he and a friend used to install them on RV's in the 90's. He's on the look out for me for a used one. I'll look into the Trans Go. Thanks.
seanhatesregister
