Davidj
- Sep 19, 2023
- greensburg
- David
- Silverado/c10
- 350cfm
i've been following along with @NickTransmissions videos and i'm at the part where i measure clearances for the direct and forward clutches. so far, this is what i've got
Direct clutch has 4 frictions, 5 steels. feeler gauge .25 can just fit. pressure plate has 1 indicator mark. (originally this was in the forward assebly.)
forward clutch has the wave plate, 5 frictions, 5 steels and .25 feeler gauge slips in without depressing wave plate. seems i can get about .5 if depressing the wave plate fully. pressure plate has 0 indicator marks, only an "S" stamped on it. (originally in the forward assembly)
when i tried using the pressure plates in the places they originally came out from, i ended up witth about .75 clearance on both. adding an extra steel resulted in difficulties fitting a .10 feeler gauge in. my question is, Does this final result sound about right? i don' have a depth gauge so i can't do the air method in his videos. this is the best combination of frictions/steels/plates i could come up with to get under .40-50 and keep it over .15. just want some reassurance before moving forward. thanks in advance for all help! and thanks many many times over for @NickTransmissions videos. cant thank you enough. truly.
