TH350 Cooler Lines
1982K20
Canada
Nick
Hi everyone, new to the forum. I have a 1982 chevy k20 that was originally a diesel. It had a 350/th350 swapped into it. Motor blew up on the guy that had it before me, it was partially being ready for the motor to be pulled then left. The transmission cooler lines are missing. I am seeking help with where I can get them other than LMC truck as I am in Canada and the shipping cost is too much. I have found a set for a 1980 k10 4wd on a website. Curious to know if those would work?
I bend up my own from parts store tubing,sold in various lengths already flared with ends on them . Dirt cheap and no waiting or incorrect fit involved.
84_c10_GMC
Alex
I just got a set from www.inlinetube.com
But I am in the states. So not sure what shipping would be for you. They showed up in 3 days and fit great on my 84.
NickTransmissions
Las Vegas
Nick
Visit your local pick-and-pull junk yards...Bring a can of brake cleaner with you to flush the lines on the spot - that way you can determine if they're clogged up or not and clean/ready them for installation...
75BEASTK20
B.C. CANADA
Cal
Thats what I did with mine and installed a REAL tranny cooler. Really helped lower tranny temperature. I don't think think the radiator cooled the fluid enough.
Yep, I've made many sets of them and with a decent tubing bender, it's fairly easy to bend them up to look factory. It's just standard 5/16" line, which any parts store *should* have in stock.
84GMCSierra
Central Arizona
C2500
I use inline tube. They have everything you need factory bent. I actually have a set of front brake lines for my 84 Sierra C2500 that I need to put on when I get my truck back
www.inlinetube.com
ali_c20
Austria
Alexander
C20, K5
I use the inline tube stainless lines, they should outlast me. Shipping to Europe is sometimes more than the parts price. Not to mention the ~27% taxes on import parts. Sometimes you have to bite the bullet if a vital part breakes.
spedigo
texas
Sam
big10
wondering on these cooler lines, just put in a new engine and haven’t hooked everything up yet. The old lines that were in there are original hard lines still in good condition , but I noticed they also have O-rings on the end of the flared fittings. As I clean everything up and put it back together Should these flared fittings have O rings or not? Also, whoever had done it before had put Teflon on all the transmission cooler line fittings. Thoughts?
Pics
jimlayhee
