yevgenievich
- Mar 1, 2014
- Place
- Name
- Year
- Model
- Size
This will be long
For sale is 1985 GMC C1500 SWB truck. Runs strong.
Asking $4500 obo,
All reasonable offers are considered
Inspection and registration are up to date(windshield was replaced so part of the old windshield with stickers is in the tool box)
Fresh 350 10:1 compression
bore is 40 over
th350 transmission
mild cam
headers
Air Gap intake
Edelbrock 600CFM carb
New air filter
Correct factory cold air intake
Power door locks and power windows work well
Good shape interior, dash with only two cracks on outer edge.
Complete interior, doors, serpentine belt system, hvac housing/controls/condenser/evap and wiring harness from 91 suburban.
It is ready for overdrive transmission with electric spedo. Has electric spedometer installed, but transmission is still mechanical. Comes with windshield GPS unit for speedometer.
All the rest of the gauges work.
Tool box goes with the truck
It is also ready for TBI conversion if desired. All the connectors are present. They can be cut off to remain carbed or drop TBI and a tune. Will come with a TBI unit if desired in a box.
Within last year ( has receipts for %80 of the items listed, some got lost/misplaced)
new door seals
outer window seals
spray in bedliner
rubber bed liner mat on top of the bedliner
Tool box
Clean windshield
Rebuilt motor (less than 3k miles currently)
New battery+battery tray(end of 2013)
New tires
New brakes (rear drums, wheel cylinders, pads etc...)
New starter
New power steering box
New power steering pump
New water pump
New alternator
New Ac Compressor, dryer, AC hoses
R134 Converted
AC/Heat works, new heater core
New blower fan
New radiator
New belt
New shocks
Sound insulation
new grille and headlight bezels
new floor liner
Good cd player/radio
Tach installed in a dash
Aluminum tall Valve covers
New exhaust - headers to single 3" with 4" diameter catalytic converter then to muffler
Has a small oil drip that I did not have time to trace yet
Will need paint and has rust in the cab corners and passenger side rocker panel.
Clean title
Asking $4500 obo,
bore is 40 over
th350 transmission
mild cam
headers
Air Gap intake
New air filter
new door seals
outer window seals
spray in bedliner
Tool box
Clean windshield
New tires
New starter
New water pump
New alternator
R134 Converted
New blower fan
New radiator
New belt
New shocks
Sound insulation
new floor liner
Clean title
