Temperature Gauge Wire HELP :)
Joshua Keith
Memphis
Joshua
Truck is a 1985 K10.
Just bought the truck and the temp gauge is not working. It has an aftermarket gauge installed which doesn’t work either, but I’m wanting to go back to the original gauge and wire or cable. The problem is I don’t know what that cable/wire looks like. I have found 2 wires in the engine bay in which the plugs are melted. This may be it, but I just don’t know. Need your help in showing me what the plug is suppose to look like.
CSFJ
Iirc, the wire for the temp sender was dark green on the older trucks. Not sure if it remained the same into the eighties.
crpntr78
Missouri
Mine is still green on my 86.
eskimomann209
Modesto
Marcus
Yep dark green and it’s on the drivers side close to the front of the engine. ( farthest from firewall)
It’s typically a single wire.
Brass sender/ sensor
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
be aware the ac and ac throttle solenoid wires are green to..
Kim Burke
Northern IN
Kim
C1500
I was wondering what the green wire was that didnt make the temp guage work?? ;-) If I hooked up an A/C throttle solenoid, that's the wire to use?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
The A/C harness is separate. it will have a 2 wire connector on the fire wall over the distributor. the light green goes to the throttle solenoid ,the dark green is the A/C clutch wire. The dark green wire for the temp gauge will be part of the engine harness.
if you hooked the ac wire to the temp sender and it had 12v on it, the sender is probably dead.
Kim Burke
Northern IN
Kim
C1500
Switched green wires and boom, temp gauge worked. I was curious(but not enough to find out) what the first wire was supposed to be hooked to. Thanks for the info, I’m always amazed at the level of expertise on this forum!
jlyon1006
