Temp gauge not working
keegansquarebody
michigan
Keegan
R1500
5.0 V8 305
Hey, i just replaced my temperature sender today. My temp gauge still isnt working. I tested it by grounding it to the engine block and the gauge didnt do anything. Im wondering how I can test it again, test the wire and maybe the gauge without taking apart my instrument cluster again. Does anyone have any ideas? Also it seems to me that my oil pressure gauge is registering to almost 60 psi when im on the gas a little bit but i just replaced the oil and filter. Anyone have any ideas about that either?
Thanks
76burb
texas
matt
suburban k20
pull the sender wire(dark green) off the sending unit and run a jumper from that to the negative battery terminal. Turn the key on. If the gauge doesn't peg to hot then you likely have an issue with the gauge or the wiring.
Might also want to check and make sure you have a thermostat installed. I spent 10 hours and went thru 3 senders and 2 different gauges only to find out that the reason they weren't working was there was no thermostat installed.
cj7_hvn
