mstumpf
- Sep 7, 2023
- Mike
- R1500
So I have a 1987 Sierra Classic with the 305 TBI. Last week my son called me and told me it wouldn’t start at school. I went and verified no spark. Replaced the distributor as well as the ignition coil. Got motor to TDC, unplugged the ECM bypass and set base timing to 0 degrees. Unplugged the battery to reset the ECM, plugged the bypass wire back in and fired it up. With the ECM plugged in, it runs like crap. When I unplug it, it definitely runs better and doesn’t stall.
Tonight I set the base timing at 6 degrees BTDC. This made things infinitely worse. Could I have a bad ECM?
