- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
3 years ago, I did the plugs on this truck and I found a whole set of em in the shed. I went online and it said a r45ts is likely what my SBC takes, but I had r46ts. I dont remember what all I learned, but i didnt want to dump money on plugs and take a trip to the store if what i had will work. Ive been running r46ts since then, and im about to do a tune up and I guess i want to confirm what plug and what gap. Iirc, .045 of an inch was the gap setting i used, but i can check when i replace em.
I know the plugs i removed had a very short gap and were also r46ts, but the thing burned oil like no tomorrow back then. Maybe my grandpa shrunk the gap and used a plug with different properties to try to alleviate the symptoms of his poorly running carb?
Amazon looks like its saying r45ts and .045 gap, the engine actually runs great now and any oil burned is negligible from my last oil change to last weekend, if the oil lost isnt actually just leaking from valve covers and my oil pan. So the oil burning it used to do, i think, was caused by it running ungodly rich that gas would find its way to the crankcase, thin oil, and oil would make its way into the cylinder, because after replacing the carb i never had to add oil, it was only a tiny bit lower on dipstick than the full mark. thats after 10 hours of a lot of idling, hauling butt in cold weather, and plowin snow.
I just figure since its running good its time for a tune up and a spruce up, poor gal is using plug wires from 4 different vehicles. Hand me downs. I know the cap is due, when i did the distributor removal when doing my intake the pins had a good amount of corrosion and the rotor looked a little worn.
