Big Chip
- Oct 19, 2017
- Michigan
- Kevin
- C35
I had a similar issue the other day but when it started to feel like it was stalling out I switched tanks and it would take off again. If I switched back to the original tank while cruising it would be ok for a while. After screwing around like that for a while I finally pulled over and looked at it. The filter was almost empty but then it would get a surge of fuel. It idled fine like that but didn't work under load. I have an electric pump and a hokey fuel routing and it was almost 100 out so I was thinking my problem was that the fuel was boiling off on it's way to the carb. I kind of ruled out the restricted line because when it cooled off it works as intended.
After I read this I don't know if you can get anything useful to help diagnose your problem but I'm not deleting. Never go backwards!!
