Swapping in dually hubs up front cclb
30backs
Middle Ga
Scott
So I converted my 1988 cclb r20rear to dually and I am really happy with the way it trueness out. I have decided to try to do the front. What all do i need to make this change and what year trucks will work? A guy down the road has a 88 but it not a classic square body would the hubs work off of it?
MrMarty51
Eastern Montana
Martin
What fron end do You have under it now ???
30backs
Middle Ga
Scott
It's the stock ifs r20 suspension
MrMarty51
Eastern Montana
Martin
OK, 2 wd.
Not sure about the 2 wd units, somebody`ll chime in.
I thought we wuz talkin 4 wd.
30backs
Middle Ga
Scott
My bad should have specified sorry.
I can't say for certain, but I think you just need dually rotors from another square body truck. I don't know if you can use them from the newer style, at minimum they have metric studs.
30backs
Middle Ga
Scott
Just swapping in rotors would be great if that's all it takes.
From what I remember it's just a rotor swap on a C30. A C20 may or may not have a different spindle/bearings, BUT a crew cab C20 is basically a C30 just with lighter springs. So you should be golden.
30backs
Middle Ga
Scott
ok wasn't sure if this was any difference because it was an R series truck.
gtewolf79
