Swapping from 15” to 20” Help with offset!
20” rims should be 9” or 10” wide? Offset?
  • 9”/0mm offset
    Votes: 0 0.0%
  • 9”/-12mm offset
    Votes: 0 0.0%
  • 9”/-18mm offset
    Votes: 0 0.0%
  • Total voters
Jeff Taylor
Jeff
Im currently running 15x10’s on all four with tires that measure 27” tall and 10” wide. I am lowered 2/4. My current rims are -44 offset/3.77” backspacing, which I don’t like. The rears are ok but the fronts stick out from fender at least 1” too much.
I want to switch to a 20” setup but not staggered.
Should I go with a 9” or 10” wide rim?
What offsets would you go with on each?
If I stay with a tire that measures max 27” tall x 10” wide, should I be ok with clearance? Don’t want any rubbing!
Thanks for all advice!!
my82blazer
