Subourbon
- Apr 28, 2020
- Quebec
- Eric
- K20 suburban
- 6.2 V8
Hey guys,
So I jumped on the cummins bandwagon and starting looking into what I'd need for a swap.
turns out its a lot. Things I hadn't even thought of!
Anyhow, someone mentioned I'd need a donor truck etc...
Then when the comments piled up and I saw how much work it is, which is fine, its a project vehicle anyhow. Someone mentioned just finding a solid Ram with the cummins and trans I like, and doing a body swap, away with the ram bed, and cab, and drop the 1982 suburban K20 body in.
Now its certainly still a fair bit of screwing around getting body mounts lined up and finding a wheel base that works. Im certainly not expecting it to be easy, but is it easier? I don't know.
Would need a wheel base that matches, and also, the heater (I'm in Canada, gonna need that). Would that line up too?
If anyones done, it, hopefully this thread attracts you all and share your stories!
Thanks everyone
Thanks everyone
