scenic760
- Jan 12, 2021
- SoCal
- Chris
- Suburban K10
Hey All,
I want to apologize to B1075 for hijacking his thread inadvertantly!
My story...picked up a 1981 K1500 Suburban from a widow in Bakersfield who's husband died and this was their ranch vehicle. It was said to run when parked about 5 years ago.. I tried getting it to turn manually without plugs, oil in the cylinders, dep creep, mmo, atf/acetone- no go. Some much wiser members suggested taking off the heads and there was a decent amount of rust on some of the rockers and all the lifters are stuck however I pulled the head on the passenger side and the cylinders don't look too bad to me (but I haven't stripped an engine down in 25 years so memory is suspect).
The intent is to get this thing set up as a nice beach/sports hauler with 4 kids to get places, very little freeway driving. I plan on redoing interior, paint, suspension so I do plan on keeping it around and I don't need to roast the tires off at every stoplight (not anymore anyways, haha).
Someone suggested just buying a used 350 and throwing it in there as you can get them so cheap.. I have looked on facebook, craigslist and google search and I can't find anything cheaper than $500 (within driving distance) and the ad said "it needs work" so seems like I would be back in the same boat more or less except $500 lighter?
Also some of the wiser members suggested an LS swap which in my situation just isn't possible, not to mention sounds like a nightmare in California. An e-rod at $10k, which to be honest is probably the best long term situation but I can't drop $10k at the moment. So I'm back to getting it on the road with more or less what it has in it (or replacing with something similar).
A couple questions I have..at this point with the head off (soon to be both) and the engine still not spinning I know it doesn't look good. Also, that much tear down I would kind of be foolish not to just yank the thing out and either rebuild or replace. I'm looking online and locally and it looks like a long block is going to set me back about $1700 minimum and a $400ish core (that I need to ship at my expense) that may or may not get refunded, so really a $2100 outlay. I'm thinking if I were to rebuild the existing short block, provided it was rebuildable, I would spend somewhere in the $1000 range? I would then most likely buy some CARB legal aluminum heads in the $1100 range (vs having existing recon'd) and pretty much be where I would be with a long block cost wise with superior performance? I have already planned to use an MSD Atomic EFI setup so basically another $1k in either scenario. Does this sounds like a sane persons rationalization?!
Thanks all!
Thanks all!
