Stumble under Acceleration
Doppleganger
OH-MI: Just like it sounds
Ok...new issue. I got my hard start thing all figured out (with the help of you fellas here)....now got another hiccup. It starts and runs stronger and smoother than ever. What I'm noticing now is, that under a hard throttle (no hole shots - just getting on it to pull out into traffic).....it will stumble and almost stall. Today, it did stall - first time ever even when it was mistimed. Started quick again but I had to be gentle on the pedal to get it home. It does get slightly better when it warms up, but still has this persistent 'dont push me' attitude.
Timing is around 12 advanced. This has a <500 mile Holly 650 the PO put on it. I loathe it - will be on CL as soon as possible. I've heard about them having issues with accelerator pumps but dont know anything about them. The Q-Jet is all fresh and rebuilt (by Mountainman FI in AR) - would put it on but think it has more street value NIB than soiled on my motor.....end goal is my iron block 6L sitting in the shed, so gotta raise $ for that.
I did hook up the vac advance to the vac port in the middle on the passenger side. Would that do anything?
Thanks in advance for any insight!
Wumbo
Illinois
Rob
I'd check the fuel filter first. Not enough flow through the filter to keep the carb bowls full.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Could be a couple things...
First, Holleys like to have the idle adjustment screws set while loaded. A second person is the best for this to keep foot firmly planted on the brake. Set for highest idle or highest vacuum while warmed and in gear.
Second, the accelerator pump operates from an arm and spring setup off the throttle. Make sure that the gap between the throttle arm and the pump arm have zero gap. You adjust the spring to arm lash by a nut on the spring. A lot of times there is a very small gap there.
The idea is that even the slightest movement of the throttle will give you a pump shot. Any gap in that arm and you can get a stumble.
I love Holleys and I hope this helps.
Doppleganger
It does help - thanks much. A local mechanic told me he prefers the Hollys but when I asked him to tune it, he acted like he didn't know how - lol.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
I had a bad fuel pump that acted a little like your stalling. Replaced pump with AC Delco and no more issues. A possibility.
Doppleganger
The one on it looks very new - which as I've found with batteries, means very little. lol
I do have a couple spare Carter's NIB. The clown that put the Holly on just twisted and tweaked the heck out of the pre-bent fuel line to make it fit (then hose clamped it anyways). I always wondered about that too.
He put a lot of thought and design into his fk ups.
Geez....this truck is a mess.
DirtyDYT
Ohio
‘79
Sounds like a fueling issue if it’s not a tuning issue. Clogged filter, dying pump, or clogged pickup sock on the sender are my top three guesses.
Does it sputter when it’s cold? If it only does it when hot then it may be a vapor lock issue related to the creative fuel line work you described.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Make sure the accelerator pump squirts fuel as soon as the throttle moves. If that’s good, you may need to play around with the accelerator pump cams or squirters.
If all else fails, get a good Q-Jet, bolt it on and go. Holley carbs are great if you want to tinker with them, it’s hard to beat the economy, power, and reliability of a properly built Q-Jet.
Doppleganger
I have the original q-jet all rebuilt and ready to go. I've also got a 6.0LS to be built for the truck - was hoping to keep the q-jet's new virginity intact for street value when the LS time comes (and $$$ will be needed).
However, its looking more and more like thats the path if I want reliability. I had a Holly on my last square body 25 yrs ago....and all I did was adjust and mess with it (it had a manual choke to boot). Went back to the QJ and it was night-day power and runability. 406 SBC and a built 700R4 - miss that truck alot.
Plus.....I know nothing about the Hollys and cant find anyone locally who does either - otherwise I'd at least give it a shot. The carb thing is temporary - maybe another year if that.
CCHEVAL1974
Paris, France
Cedric
C1500 Sierra Classic
Hi, I know it is a very old topic, but @Doppleganger did you solve this issue ? I have the same on mine (V8 fuel injection). I have ordered a K&N fuel filter, will know soon if it was the issue.
Doppleganger
My issue was the carb the PO put on was a 390 - wasn't enough for a V8 (my buddy's V6 Jeep loved it though). I had the Q-Jet rebuilt but then found out the PO cut all the wiring out when he put the small Holly on. wtf?
So got a ProFlo 4 - hoping to fire it up this summer.
CCHEVAL1974
Paris, France
Cedric
Thanks a lot for your answer. As I have an injection, my issue is different. I will see if it is getting better once the filter is changes. The old one is rusted, so it must have been there for a while...
JunkYardK10
