Stuff That Was Just Given To Me
Like the title say, buddy of mine had that stuff laying around. If anyone is interested let me know, I'll get some pics
1) On the column stick shift steering column, non tilt, 73-82,
2) Glove box doors (both look like they are in good shape)
1 A/C
1 Non A/C
3) 73 to 80 dash bezel, and instrument cluster. (Looks like it would clean up)
It's just a few things, thought someone here might need them.
J Knight
Baytown TX
82 Chevy
350ci
Got pics of dash bezel?
It's a 3 on the tree column? I think I'm interested in that.
P.S. I forgot all about sending you those nerf bars, I'll try and get that done this week!
It has all the screw holes, it does have a small chipped out piece at the bottom, clean it up a bit more, and repaint it. I don't see any cracks, in the pics it's just wet. I have a aluminum cover plate if interested also. Let me know what you think.
Yeah I think I can use that column, I don't need the steering wheel though. And that steering wheel, it's a little different than most and has an odd horn cap, that might be a hard-to-find item for someone out there.
If there ends up no takers on the bezel, I could use that too. I have the correct '77 wood overlay for it. But I can be way down on the list because I wouldn't need it for quite a while.
J Knight
Baytown TX
82 Chevy
350ci
Ill pass on the bezel Shawn, I was hoping it was a non a/c bezel.
76Stepside
New Jersey
Adam
Any pictures of the cluster? The one in my 76 is shot. Also how is the hinge on the non ac glove box door?
Skweegle89
Oklahoma
What is the difference in the AC/non AC glovebox door? Just curious.
The cluster is not too bad, does have a few of the mounting tabs broke off, but the gauges look good, and so does the circuit board.
The hinge is broken, but there is enough to fix it, the way I fixed mine, I did a write up on it, showing step by step with pics.
http://www.gmsquarebody.com/forum/showthread.php?t=620
Non A/C glove box:all open box
A/C glove box: has a 1/4 to 1/3 cut out, to make room under the dash for the A/C condenser.
76Stepside
New Jersey
Adam
I found that fix while browsing the forum earlier. I'll probably repair my existing one the same way. How much are you looking at for the cluster?
No biggie John, sorry couldn't help. I'll keep my eye out for one.
What do you want to pay? Don't forget about the ride.
76Stepside
New Jersey
Adam
Honestly this is my first square and don't really know what to offer on parts. General idea of what you'd take for it?
frank76
