Stuck Block (SBC 350 '83)
yevgenievich
Place
Name
Year
Model
Size
Would be a good idea to have an oil pan full of oil and use a drill with old distributor shaft/or extensions with flat end for spinning the oil pump to get oil through all the bearings. Pour more oil in the cylinders and keep working it back and forth. Should rotate eventually. Check for stuck valves. Tap on the top of the valve stem with a punch and a hammer to get them free if stuck.
highdesertrange
kalifornia
mike
k30
move it back and forth until you get it to go all the way around. watch for stuck valves. highdesertranger
Georgeb
Wisconsin
George
K10 Burb Z71
I agree on watching for stuck valves. A little time now to make sure they are free could save you a pile of work down the road by preventing bent push rods.
Tdabney
