Strut Compressor Tool
davbell22602
Bunker Hill, WV
I Dont
Have
One
animal
Lee
c10 silverado
350ish
davbell22602
Bunker Hill, WV
I Dont
Have
One
I personally like the top one. It looks a little safer to me. I never liked using the ones like the bottom set. They make me a little nervous. JMO
I used the bottom one too. I was taught to crank little at at time on each otherwise the spring would fly off. Least the bottom one has pins on it to help hold the spring in place.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
I would agree with animal that top one is easier to use.
As far as safety goes there is always a chance they can pop out, But Dave even the bottom ones have safety rods that keep the strut from popping out. I would still get the Top one over the bottom though. Or if you really want to be safe you a wall mounted press from branick http://cgi.ebay.com/ebaymotors/Bran...t=Motors_Automotive_Tools&hash=item20b777617b
Swims350
Logan WV
none
rent the one autozone has, why buy one if you are only doing it once?
Then again if you got the cash buy one, then you'll have it just in case.
I got a huge one, it's what shops use, big old huge square deal that goes on the outside.
davbell22602
Bunker Hill, WV
I Dont
Have
One
This will be the 3rd time doing it. The first 2 times I rented the tool from autozone which was the same cost as buying it new from them.
Swims350
Logan WV
none
yea I know that, that's why or how they do it. You buy it, use it, bring it back for refund, or if you don't bring it back, then you just bought it.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
How do you get the top one to compress?
84c10454
