Marcos
- Dec 24, 2018
- Pecos
- Marcos
- Jimmy
I have a 1980 GMC Jimmy that im having some minor issues with but its driving me crazy. Jimmy runs great!, everything works the only thing is that if you turn the key to start it nothing happens. The trick to starting it is you have to apply slight pressure on the shifter on the steering column to do so. I thought maybe the issue was the adjustment on the ignition switch. Ive tried adjusting both directions even replaced the ignition switch but still having the same issue. I haven't tore into the steering column as im trying to avoid doing so but will if need be. Any help or suggestions would be greatly appreciated
