Jon Karnes
- Jan 16, 2018
- Shreveport, LA
- Jon
- V20 Suburban
- 5.9 12 valve Cummins Conversion
I have an 87 3/4 ton suburban 4wd. I did an engine and trans swap for a 5.9 12 valve and 47RH. Love this truck. I built it to be a daily driver commute vehicle. That said, the steering on it is really sloppy. When I had the swap done, they rebuilt the entire front end. New springs, every bushing replaced, all new ball joints, and all new bearings. Basically everything that could be replaced was replaced. Also a faster ratio gear box. I got a local shop to adjust the steering box about 1/4 turn and that took a bit of the slop out with out making it too twitchy. But then I went and put those bigger tires on it and it's back to being all over the place with about 4 to 5 inches of play in the wheel. It's so bad now that it feels dangerous over 50 mph. The guy that did the build said it's just the way these 3/4 ton 4wds are, that they had a lot of slop even when they were new. With modern tech, there has to be a way to be able to drive at 70 mph and be safe. Any suggestions are welcome. I've heard some say that a steering stabilizer will help. I don't see how, it doesn't jerk out of my hand and I don't see how that would remove the play from the wheel. I don't know enough to even know where to begin. Please help!!!!
