stepside lights
Ken B
indiana
ken
Anyone know where to get stepside tail lights with factory round plug connectors?
Doylestown ohio
K10 Silverado
What year? Just ordered mine 77-87. Got part number if you need the same year.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Ken B
indiana
ken
jim if you could share where and part number I will look into it, thanks
These stepsides have the holes for the wiring to pass thru that would be wasted and look like crap unused in my opinion.
Looking for the wiring all the way back and would really like it close to factory to use those holes and be good strong connections like those factory rubber ones are/ were.....
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
I have a set of stepside rear lights and the original wiring harness that I removed from a parts truck many moons ago. In a box in my cave somewhere, will locate them later this afternoon and post a pic to see if this is what you are looking for. Best I remember they had the type connector you are looking for on the wiring harness:cheers:.
Doylestown ohio
K10 Silverado
I went to grote industries found part number and found them on Ebay. They have them in standard bulbs or led. 52802 52812
Ken B
indiana
ken
sounds promising. let me know, thanks!
Ken B
indiana
ken
great info, appreciate it
Doylestown ohio
K10 Silverado
I switched from fleet side to stepside and I dont have the stepside wiring . just gonna make the fleet side wire work . Solder and heat shrink.
Paladin
"Teufelshunde"
This is what I have, some of wiring not the best of shape but could be repaired but it has the connectors you are looking for I think.:cheers:
Doylestown ohio
K10 Silverado
Does the plugs rest in side these hole
s?
s?
Yep, supposed to.
When I was looking for the correct taillights and harness 8 or 9 years ago, they seemed to be unavailable. All you could get was the light housing with a no-plug harness. Nice to see that the aftermarket is 'stepping' up... lol.
Ken B
indiana
ken
Resurrection of an old thread. Stepside lights need a ground( at least mine do) that i ran from the light mounting stud to the frame, works great looks like Sh!T . how can stepside lights get grounded with the factory wiring harness and not look like Sh!t??
2manysquares2care
