Stepside Fender and Step attachment Question.
79K10Step
TN
Bert
I am in the final stages of 79 k10 restoration just finished sandblasting the stepside bed. My question is I am going to epoxy primer bed sand and paint. When attaching steps and fenders that have been painted to bed I will use self leveling seam sealer but wondered if I need to put something where the metal to metal fender and steps attach. In the past I have used fender welting but its a pain. That is why I am going with seam sealer. Just wondered if I should use some type of foam or gasket for the metal to metal attachment as that was where rust presents in the past? Using stainless bolts btw.
1STLS1
West Phoenix AZ
MIchael
The factory seam sealed them together then had a quarter round bead to keep debris out of the top of the mating area, you may need to blow the pictures up to see. This was a bed I took apart that I believe was never disassembled. Note the clear stone chip guard on the step.
79K10Step
TN
Bert
Thanks for the thoughts and pics the stone guard on the step may be a good idea for mine.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Putting a foam gasket in there would probably make the issue worse honestly. Sounds like that would give moisture and dirt a place to hang out. Covering up that seam entirely would be the way to go
79K10Step
TN
Bert
Thanks may be a job for POR 15
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
I think Mar-K in OKC sells a gasket for that joint. Fender welting-Current catalog-page 39 PN 120286 30' roll for $35.
86mike
