VAL
- May 29, 2012
- TUCSON, ARIZONA
- VAL
- K10 SILVERADO
A couple weeks ago I put in a new steering gear box, put the pitman arm and drag link together, took it for a spin, adjusted the drag link so my steering wheel was centered, all was good. Then all of a sudden a couple weeks later, I'm driving around normally, and my steering wheel is off center about 15 degrees. I keep driving around for a while, and my steering wheel return back to the center position. I assumed it was the drag link adjuster that slipped a thread, and it check out fine. I also looked at the leaf spring pins and they are in tact, thought maybe the spring was slipping in the perch. I can't seem to find out why this is happening.
