Steering slop
Sydney C10
Sydney, Australia
Josh
Is your lower column bearing ok? I have a little slop in mine and found my bearing is basically non-existent
saltdog
US
K20 Suburban
@Brysonsproject Check the gear to frame bolt torque is 80Ft Lbs. If less, they work loose and it will make your steering sloppy when all else is tight. Easy test is to unlock the steering wheel lock and move the rag joint by hand. If the gear moves, the bolts are loose. Happened to me didn't find it until it was super sloppy. Even passed inspection.
89GMCJimmy
ivan
Borgeson makes a shaft to eliminate rag joint
Hgwilly
