Steering shaft binding
78k10bro
washington
james
chevy k10
I cut off the rag joint on my k10 to help with the slop in the steering, now the steering is a lot tighter but harder to turn. Could it be binding? It also has cross over steering that’s brand new.
nvrenuf
Mobile, Al.
What did you put in place of the rag joint?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
So did you replace the rag joint with a new one or a universal joint or what?
78k10bro
washington
james
chevy k10
I just bolted the pieces that connect the shaft and the box together
CalSgt
CA
Casey
Rag joint allows for a little misalignment of the shaft and steering box. I’d start there…
If you are looking for a tighter sportier steering feel than a rag joint there’s a few threads on this forum where guys have figured how to swap in Jeep Cherokee (I think) steering shaft’s
SquareRoot
Yup. I did it. Great mod and bolts right in without creating a death trap. Lol
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
You can go to speedway and get all kinds of builder parts to make your own. I got this one for a different truck but they have a ton of different options in spline count or d shaft style with weld on or through bolt version. All with needle bearing u joints. I got 2 of these joints and a shaft for IIRC under $100. Correct splines on 1 side and a hole in the other to take a 3/4" round bar shaft.
R Carnella
Long island
Rich
Suburban V2500
Just bolting the pieces together without the rag joint will absolutely cause a binding condition.
And most likely will eventually break and come apart.
jlyon1006
