DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Have any of you had experience replacing the steering column sector gear and rack for the steering wheel lock feature? Is it a pain to tear apart the steering column to get to the parts? Right now my jeep is dead. I can't even jump start it because I can't shift the transmission out of park in its current state.
On January 31st I heard a very audible cracking sound within the steering column on my 1991 Jeep Cherokee when I got back to work from lunch and turned off the ignition. Went to leave work after my shift and I couldn't turn the key in any way but backwards to the accessory position. The next day I got a lock cylinder for it, tore apart the column at work to replace the lock cylinder, but the original lock cylinder was fine. The problem is further in the column, as the shaft that the lock cylinder turns, won't turn with pliers or the new lock cylinder. My guess is the Sector Gear and/or Rack have failed. Other than this issue the vehicle is a great vehicle, this is the only thing that is keeping it from starting. It runs great and has been the most reliable vehicle I have ever owned.
I have looked online and it appears Jeep used GM steering column components so I may still be able to get the parts. Some sites say the parts will fit, others say they won't and they all seem to have questions from people with GM vehicles asking if the parts will fit their GM.
