Static Drops
DirtyC30
KS
Anthony
C30
4/5 drop using DJM upper and lower control arms with Bell tech springs in front and Bellt Tech shackle and hangers in rear.
Looks good, although I am undecided on the extended squares.
blaznlow79
abilene tx
marc
jimmy
here is mine
6/8 drop
chassi tec 3" springs and 3" spindles
flip kit in rear
in process of putting a dropped cross member in
chevyman73
concord CA
Mario
2.5 inch mcgaughy spindles and beltech 2inch coil. Shackle and hanger kit with no over load leaf will flip as well
scmonsterchevy
swartz creek mi
zak
stepside short box c10
here is my first lowered square body its an 82 fleetside with a 350 with a mild cam and headers and the lowering kit is a flip kit in the rear and then 3in coil drop in the from im currently workin on its brother a 82 stepside im gonna bag ill get some pics of that one up soon
LS1Cheyenne
dont know how much its lowered but its as low as i could get away with for driveabilty. front is 4'' off the ground tho.
front - wheels 18x6 tires 26x8
rear - wheels 20x16 tires 31x18x20
therapy
Alabama
Joey
Spindles and springs up front with flip kit in the rear..
J Knight
Baytown TX
82 Chevy
350ci
4.5/5, 2.5 spindles, 1 round cut off of stock springs, flip in the rear.
C10Adam
'85 burb
2.5" spindles and 1 coil cut in the front, and flip'd rear
It's currently on jack stands as I am baggin it, complete soon, but this is still static....
87hotrod
Lula, GA
Dustin
I've never seen an ext cab before
asb2106
Kenosha WI
Tony
Heres my 79 c10
at stock stance
with 2.5" spindles and 3" shackles in the rear
the way its sitting right now
the 4.8 lr4 and 4l80e going in :)
:drool: Nice truck! When you say 3" shackles, do you mean they are 3 inches longer, or they dropped the truck 3 inches? How much of the bed cross rail did you have to cut?
exclusives01
Las Cruces, New Mexico
Hector
4.1 6cyl
1981 gmc 1500
Here's my 81 GMC Sierra. Cut coil and a half from front and flipped the axle in the rear. Very cheap way to drop, and if you don't mind a little bounce, it's the least expensive way to make your truck look alot better. Unfortunatly, I was hoping this drop would fix the one inch lean to the driver side but no luck.
Great thread.
J Knight
Baytown TX
82 Chevy
350ci
Great thread.
Looks nice but you shouldnt have any bounce, did you cut out the bumpstop mounts front and rear?
exclusives01
Hector
4.1 6cyl
J Knight:
No haven't cut the bump stop yet. Actually this weekend I will. It really only bumps when I go over ruff streets or railroad tracks.
Anyone:
Looking for the steering column cowl for the 3 speed shifter if anyone has one please let me know. Thank You
seanhatesregister
