jreed
- Mar 31, 2014
- Dalllas
- Jonathan
- 1500 Silverado
this is my first post here, and Ive got a 1980 C10 with a 350 and am having starting problems with. Truck has been sitting for a year and i just dropped a new battery into it. Pulled the starter, had it tested, and everything checks out. Verified the ground to the chassis is clean and tight, the cable to the starter is clean and tight, and even replaced a number of wires from the harness due to insulation cracks. still, she wont turn over. I know ive got electricity to everything else, but i dont even get a click from the starter. Could it be the ignition switch? Neutral Safety Switch? i seem to remember a trick for putting the truck in neutral and gapping the terminals on the starter solenoid, but dont remember the details and dont feel like burning anything up. If the ignition switch is bad, do i have to take apart the entire column? or is there an easier way to pull it?
Any help would be appreciated, guys.
