Jake292
- Mar 1, 2012
- Fort Worth, TX
- Jake
- r10
- 350 efi, 700r4
High voltage is usually a vac leak, or looowwwww.
Check the reference voltage supply at pin C of the MAP sensor (gray wire typically). Measure voltage between pin A (ground) and Pin C (+5 V ref) with a DVM. It should be right around 5 Vdc. With Key on engine off the MAP voltage (Pin B, light green wire typically) should read around 4.8 to 4.9 volts. If it reads the same as pin C the sensor is probably is history. Also check ground reference pin A. With everything off, measure resistance between Pin A and electrical ground (stud next thermostat). It should be fractional ohms.
Another functional check – with engine idling MAP output voltage (depending on idle vacuum) should be in the neighborhood of 1.2 to 2.0 volts. If it is stuck at 5 volts, check grounds and most likely MAP sensor is history.
everything checks out except the ground it shows around 50 ohms form the pin to the negative terminal on the battery. the MAP sensor in new as of December so it should still be good.
